Mach Discussion => General Mach Discussion => Topic started by: CNCAddict on October 20, 2008, 09:26:49 PM
Hey guys, not sure if I'm doing something wrong, but I can't see the tool tip in Turn. When I run a program I get a nice green line showing the tip location, but while manually jogging I get no verification on the screen. Is there a setting I need to change for this? BTW I'm using a smoothstepper with the Mach3 dev version R3.041. Anywho, other than that I'm blazing parts out left and right, woohoo :)
Afraid thats just the wy it is :(
That's not good at all :( In Mill I usually jog around to reference points on the part for a sanity check before hitting the big green button. In turn I can't even tell if I'm in the same block other than trusting my zeros are correct. Maybe I'm just anal, but this seems like a pretty problem in usability.
