Hello Guest it is November 13, 2026, 08:02:56 PM
Author Topic: Diplay problems  (Read 29064 times)
Offline spnar
  •  53 53
  • Little workshop on a little island
Diplay problems
« on: October 18, 2008, 10:39:27 AM »
Hi Guys
I am getting a " Displayfile reinitialization . Error report" when i post gcode for Lazy turn
Can anyone help as to the cause
Spnar :'(
Offline spnar
  •  53 53
Re: Diplay problems
« Reply #1 on: October 18, 2008, 10:43:07 AM »
Sorry there that should have read when posting gcode to Mach turn
Spnar ???
Re: Diplay problems
« Reply #2 on: October 18, 2008, 09:24:56 PM »
Hi Spnar,
I assume this is happening when posting gcode out of lazycam turn directly into Mach Turn.
Can you post the gcode and lcam file and I'll see what happens on my end?
Never got an error report so can't explain it.
Offline spnar
  •  53 53
Re: Diplay problems
« Reply #3 on: October 19, 2008, 02:05:45 AM »
Hi Rich
Will do
Nice Mustang is thet yours ?
Spnar
Re: Diplay problems
« Reply #4 on: October 19, 2008, 06:11:56 AM »
Yes, just one of the toys filling the drive driveway.
Post the fiiles as i am curious.
Offline spnar
  •  53 53
Re: Diplay problems
« Reply #5 on: October 19, 2008, 12:59:32 PM »
Hi Rich
Found the cause of the problem .
My PC going nuts and making my life more interesting.
Some system file must have gone crazy.
That's fixed and have started cutting some samples
I am posting photo of finished product and relevant files.
The photo shows a slightly modified version of the files attached.
Spnar
Re: Diplay problems
« Reply #6 on: October 19, 2008, 03:26:59 PM »
Spnar,
Must admit how easy that was using Lazcam now that it's done. ;)
BTW did you notice that you can go into tools "Scale Drawing" thus changing the units.
Happy you found what was wrong.
Re: Diplay problems
« Reply #7 on: October 19, 2008, 04:14:01 PM »
Thought I'd try to load this and I get an error "J word given for arc in xz plane line 37"
Do I have a setting setup wrong somewhere?
Re: Diplay problems
« Reply #8 on: October 19, 2008, 05:17:26 PM »
Dave,
Yep and be carefull. Here are just a few.
1.add a G21 so your in metric units.
2.ports & pins > no check on reversed arcs, and radius mode
3.general config>distance mode & ij mode checked for absolute
Now this is important. I assumed that the file was cleaned up by Spnar.
When the file was loaded into Mach Turn i got errors, those goofy circles, and couldn't even see it on my screen.
I changed the above settings and "magic", everything is clean and no errors. ( there is one liine which needs to be changed from an XZ move to individual moves).
Dinner is served, will get back in an hour .
Re: Diplay problems
« Reply #9 on: October 19, 2008, 06:08:51 PM »
Ok, thanks as always, Rich. I went through with the settings you showed and had "some" success. I'm still coming up with the cropcircles but at least the profile is there :D
