Hello Guest it is October 20, 2026, 03:00:56 PM
Author Topic: digitizing  (Read 14685 times)
reset131
digitizing
« on: June 26, 2006, 09:29:12 PM »
How do I get data into Rhino3  from Mach2 or Mach3 when using the digitizing wizard?  It appears that the data goes to a txt file.  Any suggestions regarding translation into a Rhino compatable format?
thanks ken
Re: digitizing
« Reply #1 on: June 26, 2006, 10:46:34 PM »
I don't know Rhino but you are loading a point cloud :)
www.newfangledsolutions.com
www.machsupport.com
Re: digitizing
« Reply #2 on: October 25, 2007, 10:46:55 AM »
Take your data file and rename it with a .txt extension  (the Mach3  3d plugin leaves off the .txt extension!)
Then in Rhino just Open>File and scroll down to the file type "Points File (.....*.txt) and select that.
Rhino will display your point cloud as a web of dots.
Rhino needs the .txt extension to see your data file.
That much I found out yesterday!
LionelB in Durban, S.Africa
