Hello Guest it is October 30, 2026, 11:51:07 AM
Author Topic: Question regarding solid shapes!!  (Read 16701 times)
« on: June 26, 2006, 05:26:09 PM »
HI,
I´m not sure if this is the right forum to post this I use AutoCad and I want to cut solid shapes for example I have a square 1/2 Inch thick wood and in the midle of that square I want to cut another square only 1/4  of an inch Thick in depth, how do I accomplish that in my drawing software say Autocad that will be recognised by Mach 2??
Thanks.
Roberto
Re: Question regarding solid shapes!!
« Reply #1 on: June 26, 2006, 06:14:53 PM »
You will need Cam software to read the 3D solids :(  LazyCAM will only take in a 2d file.... Google "Cam CNC" That should get you started :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: June 26, 2006, 06:19:39 PM »
What If I want to open holes for example just a round hole to put screws in ?? How can I set that on the machine?? Should I set like a small dot on the drawing for example??
Regards.
Roberto
« Reply #3 on: June 26, 2006, 06:33:14 PM »
Are you talking about teaching the machine the position? If so there is the teach wizard but it will not do points at this time :(
If you would like to do it with AutoCad you can save it as a 2D file and all points will be drilled
www.machsupport.com
