Hello Guest it is November 01, 2026, 01:04:10 PM
Author Topic: trouble posting code  (Read 26276 times)
Re: trouble posting code
« Reply #10 on: October 20, 2008, 06:46:00 PM »
I have a license under the latest Mach3 build and of course the beta Lcam. I had a file I worked on that was ok and after making some changes it would not post the edited code. just before this ity had locked up and needed a reboot of my system... :o
   Gonna try to work on a dxf upload to see if it works for this.
« Reply #11 on: October 20, 2008, 08:56:57 PM »
johannescnc,
You may want to get in the habit of saving the file as lcam at some point in the process. This way if somethinig goes wrong you can go back to that point in the process.
Rich
« Reply #12 on: October 23, 2008, 06:43:08 AM »
backing up my files is not the issue... BUt have resolved to using an alternative in CamBam... Works great!  ;D
« Reply #13 on: April 03, 2009, 02:00:01 PM »
Hi, I have problems with G code generation in LazyCam:
When I  import a DXF file, if I generate a G code at this time they create a file, And if the Mach3 is running they load the Gcode.
But when I generate an offset, or a Pocket LazyCam generate layers, but no longer works "Post Code", it says "File posting posting File Complete" but does not create a file that is not sending the gcode to Mach3 ....
I have conducted hundreds of tests, but once generated the offset or Pocket, they stops create GCode..
Any idea what happend? ???
(I bought the license for Mach3 and I use Llazicam'm version 3.0.0.2)
