Hello Guest it is October 11, 2026, 06:15:18 AM
Author Topic: Desktop verses laptop  (Read 15129 times)
« on: June 05, 2004, 08:16:17 AM »
Is it just my imagination or does a desktop system just work better , everything went great upgrading from my laptop to desktop including importing all the settings but when I try to access the pins settings In the config menu I get this warning..... ???
« Last Edit: June 05, 2004, 08:17:53 AM by Peter Zicha »
Re: Desktop verses laptop
« Reply #1 on: June 05, 2004, 08:34:39 AM »
Hi Peter
I have just been through a similar experience, problem with my PC, had to build another, transfer went perfectly, and i did it as follows.
Copied the old Mach3 directory over to the new PC
On the new PC i installed Mach3 as per normal
HTH
Phil_H
« Reply #2 on: October 13, 2008, 05:47:42 AM »
Never saw that one. Make sure you you reboot per installation instructions. The latest test veresions  automaticaly
do a reboot. May want to try downloading and reloading again. Post the version you are installing.
« Reply #3 on: October 13, 2008, 09:44:24 AM »
Peter, that looks like a flash screen, possibly it might have to do with that?
Possibly try a standard screen and see if you still have that issue?
« Reply #4 on: October 13, 2008, 10:19:27 AM »
The only time that will come up is if I go into the config editor and try to access port and pins everything else is accessable - other than that since I over wrote the new install with the mach3 system from the laptop everything is as it was on the laptop , works beautifully and much smoother , and I did the reboot . Its no big deal since everything still functions at 100% but was curious if Art can shed some light on this one
« Last Edit: October 13, 2008, 10:23:51 AM by Peter Zicha »
