Hello Guest it is October 05, 2026, 04:57:14 PM
Author Topic: Z axis help  (Read 14869 times)
Z axis help
« on: October 08, 2008, 07:42:38 AM »
I am new to CNC, what is the best way to zero Z axis on my material, so I don't leave a mark when turning on my router. Do I set the zero on my material, turn my controller off and back off of piece manualy. I do not have homing switches. Thanks
Re: Z axis help
« Reply #1 on: October 08, 2008, 08:06:10 AM »
Just jog to the point you want 0 to be. You can use a sheet of paper between the cutter and work so you don't leave a mark. jog down slowly as you slide the papre and as soon as the papaer quits slideing, stop jogging. Go to the z button beside the Z DRO on the program run page and click it to 0 your DRO.
Re: Z axis help
« Reply #2 on: October 08, 2008, 01:58:21 PM »
Thanks for the help, Mailman
Re: Z axis help
« Reply #3 on: October 08, 2008, 03:58:53 PM »
another similar way would be to jog down to near the surface then back off a bit whilst trying to slide a feeler gauge or gage block under. When it slides under nicely you can then enter the thickness of it in the Z DRO and now your cutter is set for the top of the work. The reason you dont jog down onto a feeler or gauge block is you will damage your cutter if you feed a bit too far, jogging up and repeatedly trying to slide the feeler or gauge under wont do damage.
Re: Z axis help
« Reply #4 on: October 08, 2008, 04:03:26 PM »
Good tip Hood.  :)
