Hello Guest it is October 22, 2026, 09:53:55 AM
Author Topic: Installation fails during install of 3.041  (Read 53689 times)
Re: Installation fails during install of 3.041
« Reply #10 on: October 12, 2008, 01:30:22 PM »
I never get to the point where I get to check anything. I double click the icon and the cursor momentarily changes to the wait cursor then changes back and maybe 10 seconds later I get the error message.
« Reply #11 on: October 12, 2008, 01:33:14 PM »
Sounds like windows is hosed ... You may need to reinstall..
www.newfangledsolutions.com
www.machsupport.com
« Reply #12 on: October 12, 2008, 03:22:00 PM »
Problem solved. It actaully was caused by something i have never seen before, a bad USB drive. I keep my mill PC disconnected from the the internet so I don't have a bunch of overhead caused by firewalls, virus scans, popup blockers, etc. To put the software on my system I used a USB drive and it seemed to copy fine. In fact I tried it 3 times and each time it had the right byte count but when I tried to install it hanged as I described above. Instead I connected my PC to the net and downloaded and installed 3.042.014 flawlessly. Weird one. Thanks for the quick responses!
« Reply #13 on: October 12, 2008, 06:19:04 PM »
I wish there was a way to pass out a prize for the oddest problem :) I think you may get it LOL..
Thank you for your hard work at finding the solution... I never would have gotten that one :(
Brian
www.machsupport.com
