Hello Guest it is October 23, 2026, 11:05:27 PM
Author Topic: Thread Milling...  (Read 15803 times)
pbreed
Thread Milling...
« on: June 19, 2006, 12:56:09 PM »
Can Mach 3 do Thread milling?
If so what hardware support is required from the spindle?
An index pulse, a series of pulses like the lathe?
Anyone have any Guidance on setting this up?
Re: Thread Milling...
« Reply #1 on: June 19, 2006, 02:37:12 PM »
Hi
No special hardware support is needed. The pitch on thread milling is not dependent on the spindle revolution's like on a lathe.  The pitch in thread milling is normally measured on  the Z axis and this is done internally in Mach3,through the interpolation between the different axis involved.
Hope this helps
Deon
If A is a success in life, then A equals X plus Y plus Z.
                               Work is X: Y is play and Z is keeping
                                                             your mouth shut.
« Reply #2 on: June 19, 2006, 02:42:24 PM »
Hi
Forgot to mention that the Newfangled Wizards has  fabulous Thread milling capability's.
Have a look at the demo conversational Wizard in Mach 3...
                                                             your mouth shut.
