Hello Guest it is October 20, 2026, 10:45:39 PM
Author Topic: reinstalling mach3  (Read 37368 times)
reinstalling mach3
« on: September 28, 2008, 09:00:28 PM »
how to reinstall mach3.................mike hide
Re: reinstalling mach3
« Reply #1 on: September 28, 2008, 09:41:49 PM »
Mike,
    Just run the installer again.  Rename your XML file, or do the new install to a different directory, then copy your XML over after the install.
« Reply #2 on: September 30, 2008, 12:52:54 PM »
Thanks Ray for your help .I have been piddling with this for some time and still no joy . perhaps the installation from the start was not correct .Iam still having problems with mach mill . whhen I hit the icon I get a flash screen showing the mach mill introduction screen then everything just goes blank . If I do the same to the turn iconit brings that uo fine  withe the lazycam icon I get a notice saying I have a mach2 version loaded.
I went back to the downloads section and loaded the latest version [I think of may this year] I still have the same problem .Now I dont know ifthw whole thing is messed up or not seems what I downloaded was not he complete system otherwise the mach3mill should have turned up when selected .
To complicate things even more I have indications that ,Lost "enable40.dll" as far as that is concerned I have checked and thayt folder is still in Mach 3 folder.Other things that do not seem to be in the path are c:\winnt\system32; c:\winnt\system.
In short I am totally out of my depth and need very explicit instuctions if anyone knows what is wrong..From an absolute bald headed [all hair removed] novice,by the way I have searcged for the "installer " and there is no file by that name on my hard drive   regards mike hide
« Reply #3 on: September 30, 2008, 01:28:34 PM »
Before reinstalling, save your mach3mill.xml and license file (something like mach1lic.dat).
Joe
« Reply #4 on: September 30, 2008, 04:41:20 PM »
Mike,
    I'd suggest you backup your XML and license files, then go to ControlPanel->Add or Remove Programs, and un-install and Mach2, Mach3, LazyCAM, etc. you find there.  Then go into MyComputer and delete the directories, if the un-install left any of them lying around.  Finally, re-install Mach3, and copy the XML and license files into the new install directories.  Sounds to me like you've got a mix of Mach2 and Mach3, perhaps installed on top of each other.  The bext thing to do is just start clean.  It should be very simple....
« Reply #5 on: October 01, 2008, 01:32:35 AM »
This is some what scary as far as I am concerned. regarding the xml files is it ok ito copy them to a removable drive[memory stick]  and do i copy them all ?
Secondly I got into the existing registry and did not see any Mach files even when I expanded most of the arrows,if you could give some guidance it would be appreciated as where they are....regards mike hide
« Reply #6 on: October 01, 2008, 09:43:16 AM »
Mike,
    Look in your Mach3 directory, sort the display by file type, and scroll all the way to the bottom.  You should see just a few files of type "XML Document" (I only have 3).  You'll probably have Mach3Mill.XML, LazyCAM.XML, and maybe a customized XML - that's the one you really need.  If you don't have a customized XML, then Mach3Mill.XML is the one you care about.  Just copy it to another directory, a USB drive, or wherever is convenient.  After re-installing Mach3, copy it to the new installation directory.
   There's no need to muck with the registry at all.
« Reply #7 on: October 01, 2008, 03:51:28 PM »
Ok Ray thanks for the help, I have the followiing xml files transferred to the external drive plus the licence. lazycam,plasma,screen4,mach3 mill.and mach3turn.
now where is the new Mach 3 filefor installation and how do i get the xml files and licence installed...? regsds mike hide
« Reply #8 on: October 01, 2008, 10:02:50 PM »
Forgot to mention mach and its bits and pieces have now been deleted , and as far as I cn see there is nothing left in the registry
« Reply #9 on: October 01, 2008, 10:45:10 PM »
Mike,
    You can download Mach3 from here: http://www.machsupport.com/downloads.php
    Run the installer, then just copy all your files into the install directory, and you should be good to go.
