Hello Guest it is November 22, 2026, 03:26:39 PM
Author Topic: Problem with Setup Screen  (Read 14439 times)
Offline Psad
  •  82 82
« on: June 14, 2006, 02:13:29 PM »
Having a little trouble with the Alt5 setup screen.  When I put in a value for the Diameter of the edge finder (.200) the coordinate system only jumps .050".  I think is should read .100 instead.
Am  I doing something wrong or
Did i misunderstand the use of the setup tool or
Is the math routine wrong. ???
Re: Problem with Setup Screen
« Reply #1 on: June 15, 2006, 06:04:42 AM »
it works here :) Be sure that you are looking at the Axis Pos on the right hand side of the screen.
If it still is giveing you trouble , upload the set file to the forum and i will take a look at it :)
www.newfangledsolutions.com
www.machsupport.com
