Hello Guest it is October 30, 2026, 12:36:16 PM
Author Topic: Spindle configuration problem  (Read 25374 times)
« on: September 21, 2008, 07:52:28 AM »
Dear friends. Sorry, but my English is not good. I have a problem with Mach PWM spindle control. I use ncPod board and it work perfect. I connect PWM to Digital converter and config Mach. After them I connect voltmeter to PWM converter output (0-10V) and I have controling voltage. If I input in Mach 18000 rpm I view 9.97V on voltmeter. But my spindle max 24000 rpm! Also I input less 8000 rpm then view on voltmeter 0V. I dont find spindle preferences in Mach. Where is I input min and max spindle rpm?
Re: Spindle configuration problem
« Reply #1 on: September 21, 2008, 11:39:18 AM »
Look in config., spindle pulley and in config., motor tuning set your vel. for the spindle motor to your max spindle RPM.
« Reply #2 on: September 21, 2008, 12:02:55 PM »
Thanks for you answer. I did it, but there is no result. In pulley selection I have Min 1000 and Max 24000 RPM
« Reply #3 on: September 21, 2008, 12:04:45 PM »
For which pulley?
« Reply #4 on: September 21, 2008, 12:10:58 PM »
First pulley. All others are identical.
« Last Edit: September 21, 2008, 12:13:49 PM by Zaryk »
« Reply #5 on: September 21, 2008, 12:15:34 PM »
Post your xml file and I'll have a look. I don't have or have ever messed wtih the NC pod so I will be limited as to what I can test.
« Reply #6 on: September 21, 2008, 12:20:51 PM »
If I input less 8000 RPM then Mach gives out the message "PWM Bumped to minimum setting".
« Reply #7 on: September 21, 2008, 12:28:30 PM »
Have you set up your spindle motor in Config, motor tuning?
« Reply #8 on: September 21, 2008, 12:35:55 PM »
Yes, but there are no changes. I have returned to standard options. I use PWM control, no step/dir.
« Reply #9 on: September 21, 2008, 12:39:34 PM »
Go into motor tuning, spindle motor and change your vel. to 24000, save axis setting and exit. See if that helps.
