Hello Guest it is October 20, 2026, 02:54:56 PM
Author Topic: :1448  (Read 12718 times)
:1448
« on: September 18, 2008, 03:24:47 PM »
When I open an *.nc file made with ArtCam, an entry in the Gcode listing right after the "%" simbol, starts with ":1448"...have to edit the code in order to run under Mach3. Is it a Mach3 or ArtCam problem?  After editing the code it runs fine without any apparent problem. Thanks for any clarification.
Re: :1448
« Reply #1 on: September 18, 2008, 03:28:11 PM »
Sounds like the Post Processor in ArtCAM needs editing.
Re: :1448
« Reply #2 on: September 19, 2008, 08:31:56 AM »
Hood, thanks for your reply. for postprocesor, I am usingĀ  a 4 axis listed in ArtCam,Axyz_Arc-INCH(*nc) dont see any 3 axis...maybe that could be the problem...not sure...
Re: :1448
« Reply #3 on: September 19, 2008, 08:57:30 AM »
Afraid I have never used ArtCAM so cant say, maybe someone who uses it will jump in with the PP they use. If not then there might be a utility that comes with it so you can open and edit it to remove that line.
