Hello
Guest
it is
September 17, 2026, 05:54:51 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Hideous Driver Tests
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Hideous Driver Tests (Read 32344 times)
Overloaded
4,923
Re: Hideous Driver Tests
Reply #10 on:
September 08, 2008, 01:57:24 PM »
I was afraid of that.......25MB +........3.5 hours on dial-up. IF it stays connected long enough.
I have the Mach CD...would it be the same file that is there in the earlier version ?
RC
Carnoustie, Scotland
Reply #11 on:
September 08, 2008, 02:11:23 PM »
Not sure Russ, do you not still have the download from the last time? maybe it will install properly again. I would think however that the file is probably the same as during testingthe only file I have been adding is the Mach3.exe.
Overloaded
4,923
Reply #12 on:
September 08, 2008, 02:14:50 PM »
OK..I loaded R3.00 from the CD and got the following TEST from the Original Driver.
2nd pic is the only file in the R3.00 folder that resembles Mach3.sys. That file is in the 008 folder as well.
I'll let it try to reload overnight.
RC
Reply #13 on:
September 08, 2008, 02:21:55 PM »
Russ,
When you are viewing your Mach3 folder (or any other for that matter) go to the tools menu then down to folder option. Then in the window that pops up got to the View tab and just down a bit you will see Hide extensions for known files (or something like that ) Take the tick out the box and all of your files will now show their extensions, its one of the first things I do when I install windows on a computer, I hate the way MS likes to hide things from me
Last Edit: September 08, 2008, 02:23:37 PM by Hood
Overloaded
4,923
Reply #14 on:
September 08, 2008, 02:42:53 PM »
Good tip, thanks ..
When I dwnlded 008 the other night, I installed it right away. I dont see it now to reinstall. Might have dwnloaded to C: then installed in C:
Would that hide the dwnload ?
RC
Reply #15 on:
September 08, 2008, 02:46:43 PM »
Nope, should sill be where you donwloaded to.
Overloaded
4,923
Reply #16 on:
September 08, 2008, 03:01:49 PM »
Well aint that just slicker n' snot on a doorknob.
Thanks Hood,
RC
Reply #17 on:
September 08, 2008, 03:04:27 PM »
Looks pretty good to me
Chaoticone
5,624
Precision Chaos
Reply #18 on:
September 08, 2008, 03:24:13 PM »
If you could see the things I have in my head, you would be laughing too.
Print
Pages:
1
2
Go Up
« previous
next »
