Hello Guest it is October 22, 2026, 02:43:56 PM
Author Topic: Hideous Driver Tests  (Read 32679 times)
Re: Hideous Driver Tests
« Reply #10 on: September 08, 2008, 01:57:24 PM »
I was afraid of that.......25MB +........3.5 hours on dial-up. IF it stays connected long enough.
I have the Mach CD...would it be the same file that is there in the earlier version ?
RC
« Reply #11 on: September 08, 2008, 02:11:23 PM »
Not sure Russ, do you not still have the download from the last time? maybe it will install properly again. I would think however that the file is probably the same as during testingthe only file I have been adding is the Mach3.exe.
« Reply #12 on: September 08, 2008, 02:14:50 PM »
OK..I loaded R3.00 from the CD and got the following TEST from the Original Driver.
2nd pic is the only file in the R3.00 folder that resembles Mach3.sys.  That file is in the 008 folder as well.
I'll let it try to reload overnight.
RC
« Reply #13 on: September 08, 2008, 02:21:55 PM »
Russ,
When you are viewing your Mach3 folder (or any other for that matter) go to the tools menu then down to folder option. Then in the window that pops up got to the View tab and just down a bit you will see Hide extensions for known files (or something like that ) Take the tick out the box and all of your files will now show their extensions, its one of the first things I do when I install windows on a computer, I hate the way MS likes to hide things from me ;D
« Last Edit: September 08, 2008, 02:23:37 PM by Hood »
« Reply #14 on: September 08, 2008, 02:42:53 PM »
Good tip, thanks ..
When I dwnlded 008 the other night, I installed it right away. I dont see it now to reinstall. Might have dwnloaded to C: then installed in C:
Would that hide the dwnload ?
RC
« Reply #15 on: September 08, 2008, 02:46:43 PM »
Nope, should sill be where you donwloaded to.
« Reply #16 on: September 08, 2008, 03:01:49 PM »
Well aint that just slicker n' snot on a doorknob.
Thanks Hood,
RC :)
« Reply #17 on: September 08, 2008, 03:04:27 PM »
Looks pretty good to me :)
« Reply #18 on: September 08, 2008, 03:24:13 PM »
