Hello Guest it is November 22, 2026, 02:26:02 PM
Author Topic: Software for process compensation moves  (Read 10046 times)
« on: September 04, 2008, 01:50:49 AM »
Hello.
I am looking for a software for lathe turning that would have:
1) for input a gcode file with compensated moves (that uses G41 G42 ....), for example the output of a mastercam software
2) that outputs the resulting moves without compensation that could be used in mach, since mach does not process the G41 and G42
Any ideias ?
Thank you
Offline da21
  •  87 87
    • M-Machine
Re: Software for process compensation moves
« Reply #1 on: September 05, 2008, 02:51:49 AM »
which verision of mach3 are you using ? , Mach has support for compensation moves G41 G42 etc
most current cam software packages support G41 G42 , can you post more information of your problem and perhaps attach gcode test file ,  comment the line you have a problem with etc
« Reply #2 on: September 07, 2008, 09:58:43 AM »
From what I am aware of, compensation is not fully functional in Mach3, at least in turn mode.
Do you use turn mode (lathe) with compensation ?
