Hello Guest it is September 23, 2026, 12:19:05 AM
Author Topic: simple AC servo speed control?  (Read 12245 times)
« on: August 29, 2008, 12:47:03 PM »
Hello to all
I'm pretty new to this, so please bear with me!
I have a nice sized AC Servo motor that I would like to use to drive a grinding spindle.
The label says 200 volts and 200 watts.
There are 4 wires coming from the motor. I'm not planning on using the encoder.
I thought I read on another forum, where it's possible to drive this motor with a "Flux Vector" VFD.
Has anyone tried this approach?
Thanks for your input!
Offline KTM
  •  92 92
Re: simple AC servo speed control?
« Reply #1 on: August 31, 2008, 09:10:39 AM »
I have never tried it, but theoretically it should work.
The motor should have three phase wires and an earth.
If you use a vector drive, set the maximum output voltage to 200V.
Most sensorless vector drives need you to enable the vector function and then to select autotune.
Also remember that a servo has multiple poles, so you might have to set the maximum frequency very high.
to get the rated maximum speed for the servo.
Regards
KTM
