Hello Guest it is October 22, 2026, 07:13:06 PM
Author Topic: Need Help , Have Questions  (Read 64821 times)
Re: Need Help , Have Questions
« Reply #10 on: August 31, 2008, 10:55:42 AM »
I did the optimistion and there was spicks everywhere . Now to the problem = my softwear will only let the machine move about 1/2 eather direction . But , I can move the table anywhere I won't = manuily . Can't make a part like that . It's all in the movement .
« Reply #11 on: August 31, 2008, 10:58:34 AM »
What happens when the movement stops? Do the motors whine?
« Reply #12 on: August 31, 2008, 11:19:26 AM »
No it just stops .
« Reply #13 on: August 31, 2008, 11:35:16 AM »
Please attach your xml and I will have a look.
« Reply #14 on: August 31, 2008, 12:01:09 PM »
Here ya go =
« Reply #15 on: August 31, 2008, 12:09:24 PM »
OK first thing I notice is you are set in imperial units but only have 200 steps per unit, I dont think that is correct. Can you give some info on the drives and motors you have and how they connect to your machine and what pitch ballscrews you have.
« Reply #16 on: August 31, 2008, 12:56:35 PM »
Here is something from another post of mine = The motors are 3 (MT23-60-5 Uni-Polar Stepper Motor) .
Here is a little more about them -
60 Oz In. Hybrid
1.8° /200 Steps Per Rev.
24 Volts*
0.18 Amps Current Draw Per Phase
5-wire Uni-polar
NEMA 23 Frame
This is where I baught all = http://www.probotix.com/    My rods are 1/4 20 rod .
How can I change imperial units to Inches ?
« Reply #17 on: August 31, 2008, 01:09:24 PM »
OK need to know whether you have any gearing between the motors and the screws and if so what is the gearing. Also need to know what you have the drives set to, they can be set 1/4, 1/2, 1/8 or 1/16 microsteps.
 You are using Inch, Inch = Imperial.
« Reply #18 on: August 31, 2008, 01:15:07 PM »
NO , I use lovejoys on all . How do I change to inches , where con I find it in the program ?
« Reply #19 on: August 31, 2008, 01:24:12 PM »
You are in Inches, you do not need to change. Your steps per unit are set wrong but until you tell me whether your drives are set to 1/2, 1/4, 1/8, or 1/16 I cant tell you what they should be.
