Hello Guest it is November 25, 2026, 12:09:39 AM
Author Topic: Need Help , Have Questions  (Read 66386 times)
« on: August 28, 2008, 09:29:42 PM »
When I load mach 3 and try 2 cut a part the table only moves about .0125 in a ismall circle . All settings are on " , so why is this happing ?
        I need Help
Re: Need Help , Have Questions
« Reply #1 on: August 28, 2008, 11:04:08 PM »
Satbeam,
Can you provide some additional  information on what your trying to do?
« Reply #2 on: August 29, 2008, 04:26:26 AM »
Maybe this is crazy but already happened to me. My post processor changed my units to metric instead on inches.
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #3 on: August 30, 2008, 11:17:11 AM »
I take it you are running some program generated by a CAD/CAM program.
Try typing into your machine on the MDI line  - assuming your are at x0y0 -
G20
G2 x2y0r1
The machine should then describe a half circle of radius 1 inch
Your machine is set in inches.
Have a look at the GCode you are trying to run and seee if, near the beginning on the code the  code G21 is included.
This changes to machine to run in millimeters and the whole thing is then 25 times smaller.
To put it right either delete the G21 or change it to G20
« Reply #4 on: August 30, 2008, 01:45:10 PM »
I have used BMP2XYZ and Mach1Filter to make my G codes . I think I need to learn to set my table size and how to change my units to inches , that might help me get started .  The problem is the movement is very poor , just the way it set up now . Maby some of my settings are wrong .
« Reply #5 on: August 30, 2008, 02:45:14 PM »
What PC/OS are you running? Did you build this yourself?
« Reply #6 on: August 31, 2008, 08:53:02 AM »
I have a Gateway with XP , and yes I built myself .
« Reply #7 on: August 31, 2008, 09:27:20 AM »
Have you optimized XP to try and get Mach 3 to run smoother?
« Reply #8 on: August 31, 2008, 09:59:41 AM »
No , I do not know how to do that .
« Reply #9 on: August 31, 2008, 10:09:31 AM »
What exactly is wrong with your machine, if you can try and explain then we will get you sorted quicker.
 The optimisation steps are on the Mach Download page, you will find it from the downloads tab at the top of the forum. Before you do that run the DriverTest and see what the graph looks like, if it has lots of large spikes then optimisation will help, if its smooth then you shouldnt need to do the optimisation.
