Hello Guest it is November 01, 2026, 10:12:25 AM
Author Topic: how to remove rapid heights from a multipass cut  (Read 8974 times)
« on: August 24, 2008, 10:05:23 AM »
I did some messing with in lazy cam and found that by messing with the rapid height and plunge clearance it reconfigured the number I am trying to remove. Now there are 2600 plus lines in this tap and I already am not thrilled about removing g0 z.32 out of this program. It is what prevents me from just running the program. If I leave it in it runs the program one hour longer that it should.  Any suggestions would be appreciated.
David
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: how to remove rapid heights from a multipass cut
« Reply #1 on: August 25, 2008, 05:41:50 PM »
Hi, David
Check your other post on this
Chip
