Hello Guest it is November 14, 2026, 05:31:59 PM
Author Topic: about REF ALL HOME  (Read 25208 times)
about REF ALL HOME
« on: August 14, 2008, 10:22:53 AM »
Hi !
I use the Mach3 v2.065 about two more years and everything was good , but I want to use MPG so I upgrade to v2.63 , and got a big
problem about REF ALL HOME , when I hit "REF ALL HOME " , first is Z axis move to home , but when Z touch limit switch , everything
is stop , than " RESET " is blink , I try so many version is same , only v2.065 can work right , is me setting wrong ?
sorry about my English!
Thanks!
Hung.
« Last Edit: August 14, 2008, 10:28:39 AM by C. J. Hung. »
Re: about REF ALL HOME
« Reply #1 on: August 14, 2008, 10:29:53 AM »
Check that they are enabled and assigned to the proper port and pins.
RC
« Reply #2 on: August 14, 2008, 10:56:55 AM »
Thanks for your reply , yes , I check so many times , the V2.63 setting is same to V2.065 .
« Reply #3 on: August 14, 2008, 10:59:04 AM »
Try setting the debounce up to 2000. If that helps, then reduce it to where it is consistant.
« Reply #4 on: August 14, 2008, 11:06:31 AM »
thanks again , but I don't know what is " debounce " , could you show me where to setting( picture) please ?
« Reply #5 on: August 14, 2008, 11:10:42 AM »
Under Config/General config
« Reply #6 on: August 14, 2008, 11:28:52 AM »
Thank you very much! I will try it tomorrow .
« Reply #7 on: August 15, 2008, 12:16:52 AM »
I set the debounce to 2000 today , and the "REF ALL HOME" function is ok !
Thanks!
« Reply #8 on: August 15, 2008, 12:26:12 AM »
You might reduce the setting to where it trips and then add a little for a buffer.
rc
« Reply #9 on: August 15, 2008, 10:12:14 AM »
ok! I will try it tomorrow!
