Hello
Guest
it is
October 15, 2026, 11:25:58 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Problems with pocket cutting in mach 3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Problems with pocket cutting in mach 3 (Read 13191 times)
swmarsh01
2
on:
August 13, 2008, 04:55:25 PM »
Hello All,
I am new to this forum but not new to cnc. Here is my problem. When I create a pocket cut using vcarve pro and mach 3 to control my cnc I get a bouncing movement on the x and y axis when going around the letters that I am carving. For example: I create a design with letters in vcarve pro. After the design process I goto the output side and save my file to cut. Now when I start my cut I have my router make 2 passes of .125 total equiling .250 cut. when it goes around the letters its not a smooth cut. It kinda jumps. now on the stright cut theres no problem. only the curves. ( Not the z axis ) This leaves a very bad finnish. Its not smooth at all. I have to do alot of sanding. I am using a hobbycnc pro board with 305 oz steppers.
Any Clue on why this is happening?
Thanks Steve
Last Edit: August 13, 2008, 04:57:19 PM by swmarsh01
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Problems with pocket cutting in mach 3
Reply #1 on:
August 13, 2008, 05:04:33 PM »
Hi Steve,
it sounds as if your software is outputting tiny straight lines for the arcs, if you do not have CV turned on in Mach3 then turning it on will help. If you have then look if Vcarve can output arcs instead of the line segments.
Graham.
swmarsh01
2
Reply #2 on:
August 13, 2008, 05:13:31 PM »
Thanks Graham for the quick reply. Ill try this tonight.
Steve
Print
Pages:
1
Go Up
« previous
next »
