Hello Guest it is November 14, 2026, 04:05:11 PM
Author Topic: Softlimits not working with smoothstepper  (Read 13895 times)
« on: August 13, 2008, 04:25:00 PM »
I have come accross another problem, my softlimits no longer work after installing my smooth stepper. They were working fine with the parallel port configuration.  I have checked my settings everything seems OK but softlimits won't work at all. Does anyone have any ideas.
Tom
Re: Softlimits not working with smoothstepper
« Reply #1 on: August 13, 2008, 04:30:19 PM »
Hi Tom,
I believe this is already known. Check out the Smooth Stepper area here:
http://www.machsupport.com/forum/index.php/topic,7920.0.html
You may also want to try the actual smooth stepper forum-
 http://www.Warp9TD.com
« Reply #2 on: August 13, 2008, 04:37:30 PM »
I actually found a link that Gregs says where they are on the soft limits function, Tom:
http://www.warp9td.com/index.php?option=com_fireboard&Itemid=33&func=view&id=1064&catid=7
« Reply #3 on: August 14, 2008, 09:53:53 PM »
I did some BETA testing for Greg a while ago on a plugin that has the soft limits working.  In this version of the plugin the soft limits performed virtually the same as they do when using the PP.  There were a couple of quirky things though and I reported all of my findings back to Greg.  I think he is/should be VERY close to releasing a new plugin that has soft limits implemented.
HTH,
Sid
