Hello Guest it is October 16, 2026, 12:25:44 AM
Author Topic: Smooth Stepper Homing error  (Read 13828 times)
« on: August 13, 2008, 11:17:57 AM »
I just installed a smooth stepper from warp9. Everything is working well except when I try to home the machine, the Z axis will hit the home/limit switch the slowly back off, but when the y axis hits the home/limit switch it seemes as it starts the mach goes into e-stop limit switch error. I have tried different setting in the smooth stepper config and in mach Debounce, nothing seemes to help.  I have read the Manuel but it is incomplete and I just am lost right now.
Tom
Re: Smooth Stepper Homing error
« Reply #1 on: August 13, 2008, 11:30:04 AM »
Check out the Warp9 site. Thought i saw something posted there on limit switches.
« Reply #2 on: August 13, 2008, 12:18:29 PM »
Get the latest plugin (13c I think) it has the digital filtering options and it seems to work very well.
« Reply #3 on: August 13, 2008, 04:20:45 PM »
I was able to fix the problem by rewiring my switch's to normally closed, and they are now working properly. Thanks for the help
Tom
