Hello Guest it is September 29, 2026, 06:20:18 PM
Author Topic: Have you ever seen Mach doing this  (Read 28551 times)
Offline CJEls
  •  69 69
« on: August 12, 2008, 02:30:46 PM »
Hi All
I have a weird problem with mach turn.When I call a tool the turret does not turn bur then I open vb editor and run the m6 script and then the turret will turn to the tool I called. I did en able tool Auto change in the general setup page .Any takers on this one.
Cj
Re: Have you ever seen Mach doing this
« Reply #1 on: August 12, 2008, 02:39:10 PM »
Have seen that before with VB, it will run fine stepping through in the editor but wont run from Mach.
Has your toolchange ever worked in Mach?
Offline CJEls
  •  69 69
« Reply #2 on: August 12, 2008, 02:53:08 PM »
Hi Hood
Yes it work with the hard drive that failed.
CJ
« Reply #3 on: August 12, 2008, 02:54:13 PM »
can you attach the macro and maybe someone will find a problem.
Offline CJEls
  •  69 69
« Reply #4 on: August 12, 2008, 03:17:01 PM »
This is the code I hope some body can help.
   Old_tool = GetCurrentTool()
   New_Tool = GetSelectedTool()
If GetSelectedTool <1 Then   'If tool called is less than 1
MsgBox("Tool Out Of Range")  'show message
End                          'End macro
End If
If GetSelectedTool >8 Then  'If selected tool is greater than 12
MsgBox("Tool Out Of Range")  'Show message
End                          'End macro
End If
If GetselectedTool = GetCurrentTool Then  'If selected tool is the same as current tool then end macro
End
End If
 If GetSelectedTool=1  Then               'If selected tool = 1
 Do                                       'Start loop
 Call ActivateSignal(output4)             'start turret indexing
 If IsActive(Input1) And Not IsActive(Input2) And Not IsActive(Input3) And Not IsActive(Input4)  Then Exit Do             'Correct tool in position signal from PLC and exit loop
 Loop                                     'Continue loop if above signal is not present
 End If
 Call DeActivateSignal(OutPut4)            'Stops turret Indexing
If GetSelectedTool=2  Then
 Do
 If IsActive(Input1) And  IsActive(Input2) And Not IsActive(Input3) And Not IsActive(Input4)  Then Exit Do
 Loop
 End If
If GetSelectedTool=3  Then
 Do
 If Not IsActive(Input1) And  IsActive(Input2) And Not IsActive(Input3) And Not IsActive(Input4)  Then Exit Do
 Loop
 End If
If GetSelectedTool=4  Then
 Do
 If Not IsActive(Input1) And  IsActive(Input2) And  IsActive(Input3) And Not IsActive(Input4)  Then Exit Do
 Loop
 End If
If GetSelectedTool=5  Then
 Do
 If Not IsActive(Input1) And Not IsActive(Input2) And  IsActive(Input3) And Not IsActive(Input4)  Then Exit Do
 Loop
 End If
If GetSelectedTool=6  Then
 Do
 If Not IsActive(Input1) And Not IsActive(Input2) And  IsActive(Input3) And  IsActive(Input4)  Then Exit Do
 Loop
 End If
If GetSelectedTool=7  Then
 Do
 If Not IsActive(Input1) And Not IsActive(Input2) And Not IsActive(Input3) And  IsActive(Input4)  Then Exit Do
 Loop
 End If
If GetSelectedTool=8  Then
 Do
 If IsActive(Input1) And Not IsActive(Input2) And Not IsActive(Input3) And  IsActive(Input4)  Then Exit Do
 Loop
 End If
CJ
Offline CJEls
  •  69 69
« Reply #5 on: August 12, 2008, 03:20:04 PM »
Hi
It seems that Mach is not seeing the m6 command.
Cj
« Reply #6 on: August 12, 2008, 04:07:29 PM »
Ha ha I recognise that code ;)
 Ok I have half tested it here and it seems to be working in as much as its switching  OutPut 4 on (seen on Diags screen)
Are you getting that?
If not then can you attach your xml to the thread.
Offline CJEls
  •  69 69
« Reply #7 on: August 12, 2008, 11:11:56 PM »
Hi Hood
The turret turnsd to the correct posistion when iI run the code in Vb.The output4 does work.
CJ
« Reply #8 on: August 13, 2008, 01:16:47 AM »
Please attach your xml.
Offline CJEls
  •  69 69
« Reply #9 on: August 13, 2008, 11:29:42 AM »
Hi Hood
got it sorted and it is working like a charm now it is the modbus that I must sort out.I can talk to the board if I run Xp cominications.I can set the port .baudrate but with mach it does not want to talk.
CJ
