Hello Guest it is October 20, 2026, 09:17:46 PM
Author Topic: shift key  (Read 14669 times)
shift key
« on: June 03, 2006, 01:06:03 PM »
is it possible to lose the use of the shift key in mach3  when i use the arrows keys it feeds ok when i try to use shift + the arrows the lathe does not move any faster thank you in advance
marcel
Re: shift key
« Reply #1 on: June 03, 2006, 01:15:01 PM »
In Mill the shift will only work if you have a slow jog rate set, so I presume lathe will be the same. If you dont have this set then the arrows will move at full jog and pressing shift will make no difference, if you have a slow jog rate set then arrows will jog at the slow speed and shift + arrows will jog at 100%
Re: shift key
« Reply #2 on: June 03, 2006, 01:44:33 PM »
thank you
you solved part of my problem and i found the other part if you tap your key 5 times in a row window's  , window's removes the association with other keys like the control key alt key and the shift key you must press shift key 5 more times to receive the window's box and you have to tell it you want to restore the association to the keys mentionned in the above
thank you again
marcel
