Hello Guest it is November 11, 2026, 09:14:59 PM
Author Topic: [MACH3 with G100] ecode=777, ecode=790, ecode=813  (Read 53328 times)
Re: [MACH3 with G100] ecode=777, ecode=790, ecode=813
« Reply #20 on: September 02, 2008, 08:50:28 PM »
Your diagram looked fine to me.
You should be able to just test one axis. It is no necessary to have all axis wired up to test one but might want to disable other axis and home switches if they are set up in ports and pins.
No Problem,
« Reply #21 on: September 03, 2008, 05:10:23 AM »
Hi Brett ...
sory about my Questions... do you think is it right if i use resistor 33K ? when power supply ON, resistor voltage is 7,21V...  i use 48 V Dc power supply with 4,2A current output to supply G201, i use 2,8A stepper motor...
also to test my motor, i must use what G-code?
Thanks very much Brett......
james
« Reply #22 on: September 04, 2008, 10:27:55 PM »
hi brett .....
how about my g100 ? it still no outgrowth....
what must i do ?
any idea ?
this is i attach how i configure my mach3...
could you check my setting ? if there any mistake...!!!!
thanks  Brett.......
i'm very appreciate Your help
James
« Reply #23 on: September 04, 2008, 10:34:44 PM »
Brett....
there are still any file i want to attach, but it can't sent......
may be latter....
sorry Brett....
