Hello Guest it is November 11, 2026, 09:15:00 PM
Author Topic: [MACH3 with G100] ecode=777, ecode=790, ecode=813  (Read 53329 times)
Re: [MACH3 with G100] ecode=777, ecode=790, ecode=813
« Reply #10 on: August 07, 2008, 04:59:03 AM »
I tried with router.
But Grex still shows me "ecode=777"
Please~~~ Somebody help me~~~!!! T.T
« Reply #11 on: August 07, 2008, 05:33:12 AM »
Regular Member
 Offline
Blog entries (0)
     Re: Communication Lost / Error 777
« Reply #3 on: August 28, 2007, 03:07:16 PM »
I was getting this message reliably along with difficulty initializing once this occurred. Got a new Rabbit and problem was solved. I still have the old Rabbit and it reliably and predictably continues to fail. Gecko has indicated a very small percentage of the Rabbit mini-computers demonstrate networking/ communication trouble.
Also see 'G100 crashing' thread for related symptoms and additional info.
The above is a quto taken from the following thread.
http://www.machsupport.com/forum/index.php/topic,2674.0.html
This one may also help.
http://www.machsupport.com/forum/index.php/topic,3797.0.html
« Reply #12 on: August 10, 2008, 11:49:34 PM »
I have seen the topic. But...I can't understand. What is rabbit?
He said "new rabbit". what means it?
Is it some plugin? or firmware?
Thanks for your kindness and reply. ^^
- Kris-
« Reply #13 on: August 11, 2008, 07:56:39 AM »
Kris, the rabbit is the micro-processor in the G100 I do believe. It is hardware. Contact Gecko about your problem and see if they can help.
« Reply #14 on: September 02, 2008, 03:33:56 AM »
hi Brett.....
i'm james.... i'm new about G100 and mach3 software ...
 i'm design g201 conect to g100 to run stepper motor...
i was setting all hardware and the connection of g100 and mach3 was ok, but the motor doesn't turning out...
1. how to set ty systemhe configuration of mach3 to make motor run ?
2. is it right if i just want to test my system,so i just use x-axis ?
thanks for any help, i will very appriciate....
sorry about my bad english .....
james
« Reply #15 on: September 02, 2008, 06:18:39 AM »
James, Have you looked at the G100 Set Uo Guide?
http://www.machsupport.com/docs/G100_Set_Up_Guide_Rev.1_9-19-07.pdf
« Reply #16 on: September 02, 2008, 06:23:43 AM »
yes i was looked.... ..
« Reply #17 on: September 02, 2008, 06:26:12 AM »
this is my design....
thx for your reply Brett....
any comment ?
james
« Reply #18 on: September 02, 2008, 07:25:54 AM »
James, your wireing looks fine to me. Looks like your using a 24V power supply? Chaeck the 5v (common on your sheet) pin and see if you have 5 volts there.
« Reply #19 on: September 02, 2008, 08:27:12 PM »
hi Brett....
Yes i use 24 VDC for supply G100 and i was check the common and there was 5 V...
do you think all the part has connect to the right pin ?
must i use 3 axis to test G100 ?
thank's  Brett...
james
