Hello Guest it is November 13, 2026, 11:36:44 AM
Author Topic: cnc stops :-(  (Read 13645 times)
cnc stops :-(
« on: July 24, 2008, 10:36:50 PM »
hi all,
i recently installed a new tormach pcnc 1100. is run by mach3. it machines wonderfully until it stops. i traced the error to the g code. there seams to be a limit of 500 lines of g code that mach 3 will accept. is only
in the mach3 window that this occours, i can edit in notebook fine which suggests that it's loading.
is there something obvious i'm missing or is mach3 limited to 500 lines of g code.
has anyone else had this happen
brad m
Offline Greolt
  •  956 956
Re: cnc stops :-(
« Reply #1 on: July 24, 2008, 10:44:41 PM »
Mach in demo or free mode is limited to 500 lines.
Check your license if you have one.
By the way are you from Avoca Victoria?
Greg
Re: cnc stops :-(
« Reply #2 on: July 24, 2008, 10:47:22 PM »
oh thanks for that.
am in melbourne, avoca is just up the road.
i originate from two other town.
daylesford and wangaratta.
i just like avoca,
Re: cnc stops :-(
« Reply #3 on: July 24, 2008, 10:57:17 PM »
problem fixed, i didn't load the licence cd. always good when it is something simple
brad
Offline Greolt
  •  956 956
Re: cnc stops :-(
« Reply #4 on: July 24, 2008, 11:28:34 PM »
Brad
Glad that got things going.
I live in Geelong and am often in Melbourne.  I would love to call in one day and see the Tormach.
Greg
Re: cnc stops :-(
« Reply #5 on: February 26, 2013, 12:16:56 PM »
I seem to be having the same issues on my end too now and cant seem to figure out what to do.
I keep getting a limit of 500 of G code and I'm not using the free or demo versions. Is it possible for you to help me
out on this end so I too can get things up and running.
Re: cnc stops :-(
« Reply #6 on: February 26, 2013, 12:18:17 PM »
Attach your xml and I will check here whether it has an issue.
