Hello
Guest
it is
November 20, 2026, 02:16:07 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
Simple G code example needed
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Simple G code example needed (Read 35808 times)
Overloaded
4,923
Re: Simple G code example needed
Reply #10 on:
July 21, 2008, 09:19:33 PM »
Hmmmm. maybe you need the .Lic file to get the wizards..but I'm pretty sure that I had them befor I got the Lic, they just would not post code.
Anyway, I posted the code for you earlier...the .tap file.
Yoyu can tweak it as you need.
RC
Last Edit: July 21, 2008, 09:38:36 PM by Overloaded
Kristin D
203
Take that you LazyCam, next stop the glue factory!
Reply #11 on:
July 21, 2008, 09:21:58 PM »
probably true, I did run the file you posted and can work off of that.
Thanks a bunch
Kristin
(now wandering off more confused than ever, where the heck is that big hammer?)
Overloaded
4,923
Reply #12 on:
July 21, 2008, 09:27:06 PM »
NO NO NO....No hammer necessary.....I tried that...only made matters worse.
rc
Last Edit: July 21, 2008, 09:34:16 PM by Overloaded
Overloaded
4,923
Reply #13 on:
July 21, 2008, 09:37:48 PM »
DANG, I'm almost CERTAIN that I fooled with the wizards befor the Lic.
Maybe you need to dwnld Mach again ? ? ? ?
Good Luck.
Let me know when you are done with that HAMMER
Kristin D
203
Reply #14 on:
July 21, 2008, 10:10:51 PM »
Just downloaded the "unstable" version and sure enough the wizard('s) are there! Sneaky Wizzards, a bad lot all of them always promising to turn lead into gold or some such!
Kristin
Overloaded
4,923
Reply #15 on:
July 21, 2008, 10:18:38 PM »
(keep that hammer handy)
trev36
25
Reply #16 on:
July 21, 2008, 10:34:38 PM »
Kristin
I wrote a short sub routine I think will work .
G90
G01X0.0Z.100F50.
Z0.0
M98 P1 L25
G90
G01X0.0
Z0.0
M30
O1
G91
G01X-.010F25.
G01Z-.500
G01X0.010
G01Z0.500
G01X-.010
M99
Travis
Kristin D
203
Reply #17 on:
July 22, 2008, 01:38:07 PM »
Travis,
That does the trick, now I need to beef up my motor mount as I can see it flexing so I need to box in the third side of my L shape bracket.
Kristin
Print
Pages:
1
2
Go Up
« previous
next »
