Hello Guest it is November 20, 2026, 02:16:11 AM
Author Topic: Simple G code example needed  (Read 35810 times)
Offline Kristin D
  •  203 203
  • Take that you LazyCam, next stop the glue factory!
« on: July 21, 2008, 07:20:27 PM »
Ha, thought I knew what I was doing almost, finally got the X & Z axis motors mounted on my Taig,
Wrote a bit of code:
g0 z0
g1 z .25
g0 z0
g1 x .01
g1 z .25
g0 x 0
g0 z0
g1 x .2
g1 z .25
etc...
Sure there is an easier way with loops but can't find the examples I have seen here.
All I want to do at the moment is say take a piece of round stock in the lathe, and turn say .5 long with repeat passes off .010" for the purpose of taking a video, I also seem to have forgotten how to put a dwell time in as I would like to have say 15-30 seconds to man the camera after I hit cycle start. Think that is g4 but can't remember the syntax like g4 P30?
Kristin
« Last Edit: July 21, 2008, 07:24:45 PM by Kristin D »
Re: Simple G code example needed
« Reply #1 on: July 21, 2008, 08:17:02 PM »
yep G4 P30 would be a 30 second delay, unless however you have it set for millisecond, check on the general config page.
And just use a wizard, put in start and finish Dia, Start and finish Z and DOC for a pass and you will get all the code written for you ;)
Offline Kristin D
  •  203 203
« Reply #2 on: July 21, 2008, 08:22:11 PM »
using the demo version and I don't find any wizards for that (darn wizards!) I think Jimpinder had an example of a loop & repeat thing but unable to locate the thread.
Kristin :D
« Reply #3 on: July 21, 2008, 08:34:33 PM »
Kristin,
Try using one of the wizards to generate the code and the add the dwell in after each pass.
See attached files.
« Reply #4 on: July 21, 2008, 08:41:19 PM »
Good timing Rich  :D
Here is the code too...ready to go. (cept maybe the feed rates, I run fast as I can)
« Last Edit: July 21, 2008, 08:42:51 PM by Overloaded »
Offline Kristin D
  •  203 203
« Reply #5 on: July 21, 2008, 08:41:40 PM »
Rich,
Where are the wizards located? When I click wizards in Mach turn I don't recognise which one may be the one you used.
Kristin
« Reply #6 on: July 21, 2008, 08:48:00 PM »
Wizards/Pick Wizard/Turning/Run/OD Turning, OD Fillet
If you leave the Radius at 0.000, it will turn to a square corner.
« Last Edit: July 21, 2008, 08:49:40 PM by Overloaded »
Offline Kristin D
  •  203 203
« Reply #7 on: July 21, 2008, 08:53:25 PM »
Turning is not there! Only Teach, Teach rev 1.4 and Thread milling, I am running the demo version.
Kristin
« Reply #8 on: July 21, 2008, 09:01:20 PM »
Which screen set are you using ?
Click: View/Load Screens/then at the bottom,files of type, Turn files.lset/1024.lset
Offline Kristin D
  •  203 203
« Reply #9 on: July 21, 2008, 09:13:52 PM »
Nope it's just not there. Loaded the lset screen and nothing in the wizards looks like you discribe.
Kristin
