Hello
Guest
it is
October 21, 2026, 12:17:20 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Charge Pump Output Check/Verify ?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Charge Pump Output Check/Verify ? (Read 14428 times)
Overloaded
4,923
on:
July 15, 2008, 09:23:38 AM »
Hey Folks,
Using a DMM, can the Mach Charge Pump freq. be checked... or just verified on its assigned port/output pin ?
Not the actual pulse count, just positive evidence of its presence.
RC
Carnoustie, Scotland
Re: Charge Pump Output Check/Verify ?
Reply #1 on:
July 15, 2008, 09:49:17 AM »
I would imagine if you put the DMM on mv range you should see something, cant test as a boats skipper just borrowed the DDM but when he brings it back I will test it if you havent had an answer from any one else.
Reply #2 on:
July 15, 2008, 10:03:44 AM »
OK just got the meter back, getting 2+ volts at the chargepump, thought it would be less but forgot its not a high frequency . So yes you should get a voltage of around 2 or 3 volts.
Overloaded
4,923
Reply #3 on:
July 15, 2008, 10:39:49 AM »
I checked as well....1.97v
Thanks Hood,
RC
Print
Pages:
1
Go Up
« previous
next »
