Hello Guest it is November 22, 2026, 03:18:40 PM
Author Topic: how to start in a certain section of the program.  (Read 15525 times)
Offline josh
  •  101 101
« on: July 13, 2008, 01:59:32 PM »
how can i start the program in the middle or in a certain section or a differnt tool number. i tryed doing it in the DRO where it says start on a certain line but when I hit start it starts in the beginning, of the program. is there sme kind of setting i have to change.
Re: how to start in a certain section of the program.
« Reply #1 on: July 13, 2008, 02:11:56 PM »
Click in the code window and scroll down using the arrow keys on the keyboard, when you reach the line you want to start from choose the Run From Here button, it will run through the code and stop at the line you have chosen, clcik start and you should get a prep move box, OK that and the tool will move to that position once there press Start again and you will be on your way.
« Reply #2 on: July 13, 2008, 02:16:07 PM »
Oh meant to say, if you know the line you want to run from you can type that into the line DRO and then press Run From Here.
Offline josh
  •  101 101
« Reply #3 on: July 13, 2008, 04:01:22 PM »
for some reason when i type in the DRO line the number i want it to start it still goes to the start of the program and it does start where i want it to  why
« Reply #4 on: July 13, 2008, 04:06:59 PM »
Are you just running the Demo version? If so that is why, Run From Here is only in the licenced version.
