Hello
Guest
it is
October 11, 2026, 04:17:41 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
m03 not turning on spindle. Spindle screen button does
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: m03 not turning on spindle. Spindle screen button does (Read 17234 times)
fixittt
290
on:
July 12, 2008, 04:33:47 PM »
Helping a friend. We noticed that the m03 code will not turn his spindle on. pressing the spindle toggle button does.
M08 will turn on his coolant. As will the coolant toggle button.
After playing around in output signals i changed pin number around for coolant and spindle. m08 will turn on the spindle but m03 will not turn on the coolant.
I played with outputs moving them all around and no matter what output number I put for spindle (m3) I cannot get this function to work. also when typing in MDI m03 the corrisponding output led does not light up like when I type m08. When typing m08 i can see the output led come on.
Any ideas?
Logged
Carnoustie, Scotland
Re: m03 not turning on spindle. Spindle screen button does
Reply #1 on:
July 12, 2008, 04:40:39 PM »
Dont have spindle controlled on my Mill from Mach so dont use it and on my Lathe I use a custom Macro for the spindle.
Have you tried doing an M3 S1000 to see if that works. If that doesnt work then have a look in the macro folder for the profile you use and see what the M3 adn also the Spindle speed Macros say.
Logged
fixittt
290
Reply #2 on:
July 12, 2008, 04:46:57 PM »
i dont use spindle m03 on mine either. but if I go into the diag screen and type m3 in the mdi line. I get the output 1 led flashing.
also if I click on the spindle toggle button I get the output led flashing.
On his neither the spindle toggle or the m03 command in MDI triggers any output led
Logged
Reply #3 on:
July 12, 2008, 04:51:05 PM »
Looks like his macro is corrupt then, have a look at your macro and compare to his. If you are using Mill and the standard profile you will find it in C:\Mach3\macros\Mach3Mill it is called M3.m1s.
Logged
fixittt
290
Reply #4 on:
July 12, 2008, 06:29:29 PM »
Hood, that was it. sent him my file and all is well. Thanks bud!
Logged
Reply #5 on:
July 12, 2008, 06:33:44 PM »
NP
Logged
Print
Pages:
1
Go Up
« previous
next »
