Hello Guest it is October 24, 2026, 04:59:32 AM
Author Topic: New Router Screen  (Read 215810 times)
New Router Screen
« on: July 12, 2008, 08:14:19 AM »
Here's a modified version of my other screen set for a single Z axis router.
 I haven't really tested it, but I think everything is working.
There is no toolpath on the Run screen. The reason for this is that CPU usage is about 75% lower without the toolpath on the screen, and when your cutting, you're usually looking at the machine, not the screen. This should make this screen run better on slower PC's than the standard screens.
Unzip all the .png files to Mach3\Bitmaps\Router\ and put the Router.set file in the mach3 folder. It's setup for spindle to use Output 1 and Coolant Output 2.
Let me know if there are any issues and I'll fix em up.
http://home.comcast.net/~cncwoodworker/CNC/Mach3/Screens/M3Router.zip
Also, here's the Real Draw Pro files if anyone wants to modify the Screens (you'll need RealDraw Pro).
http://home.comcast.net/~cncwoodworker/CNC/Mach3/Screens/M3Router_RealDraw_Pro.zip
« Last Edit: July 12, 2008, 08:27:42 PM by ger21 »
Re: New router Screen
« Reply #1 on: July 12, 2008, 08:27:59 AM »
VERY nice... I love that screen :) Nice and simple... If you would like we can put that screen on the web for you when you are happy with it :)
Thanks for showing us all your work, very few know what time is involved with a simple screen like that :) The more simple it looks the harder it was to make ;)
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: July 12, 2008, 08:32:26 AM »
Thanks, Brian.
If someone can verify that everything works correctly, then feel free to put it on the website.
Re: New Router Screen
« Reply #3 on: July 17, 2008, 07:51:12 PM »
260+ views and no comments? Is anyone using this screen set?
« Reply #4 on: July 17, 2008, 08:05:08 PM »
I got a comment for ya......200 of them views are MINE !  :D I just love lookin' at em'.
In your "spare" time, combine your beautiful work with Scott's "Practical Turn Screen" and then by golly ....I'll wear it out !
Wish I had a router just to run this one.
RC  8)
« Reply #5 on: July 17, 2008, 08:56:56 PM »
Gerry, it looks great but I don't have a router either. Your screens makes me want one even more if that helps.  ;)
« Reply #6 on: August 10, 2008, 07:29:42 AM »
Brian, you mentioned on the Yahoo group about possibly adding a router screen to the install. Were you talking about this one?
« Reply #7 on: August 11, 2008, 07:45:43 AM »
Yup,
This is the one that I was thinking about .. .I was thinking that we would take the A and B out and make it a nice simple 3 axis Screen . Only an Idea at this point ;)
Brian
www.machsupport.com
Offline Pythagoras
  •  93 93
  • a² + b² = c²
« Reply #8 on: August 15, 2008, 06:45:46 PM »
Looks good Gerry. You should request your screen be added to the official screen download section.
Benny
« Last Edit: August 15, 2008, 07:25:44 PM by Pythagoras »
The Pythagorean theorem: The sum of the areas of the two squares on the legs (a and b) equals the area of the square on the hypotenuse (c).     a² + b² = c².
scottn
« Reply #9 on: August 15, 2008, 08:36:13 PM »
Done!   :)
scott
