Hello Guest it is October 24, 2026, 06:00:37 AM
Author Topic: New Router Screen  (Read 215823 times)
Offline Pythagoras
  •  93 93
  • a² + b² = c²
Re: New Router Screen
« Reply #10 on: August 15, 2008, 09:26:38 PM »
Excellent !!! Thanks Scott.
Benny
The Pythagorean theorem: The sum of the areas of the two squares on the legs (a and b) equals the area of the square on the hypotenuse (c).     a² + b² = c².
« Reply #11 on: August 16, 2008, 01:21:54 AM »
I've tryied this screen on my router.
All work well until my bit brake.
There is no  "Run from here" to restart in middle of program.
Another thing, to find the good line to restart, i'm used to jog in the programme and look at tool path to reach when the bit has broken. But in this screen, we could not have both at a time.
To resume, it's a very good screen to use with a touch screen until bit breaking.
« Reply #12 on: August 16, 2008, 08:08:11 AM »
There's a blank button that you could use for run from here. Just need to add a small DRO to enter the line number.
« Reply #13 on: February 11, 2011, 10:23:33 AM »
Here's a modified version of my other screen set for a single Z axis router.
 I haven't really tested it, but I think everything is working.
There is no toolpath on the Run screen. The reason for this is that CPU usage is about 75% lower without the toolpath on the screen, and when your cutting, you're usually looking at the machine, not the screen. This should make this screen run better on slower PC's than the standard screens.
Unzip all the .png files to Mach3\Bitmaps\Router\ and put the Router.set file in the mach3 folder. It's setup for spindle to use Output 1 and Coolant Output 2.
Let me know if there are any issues and I'll fix em up.
http://home.comcast.net/~cncwoodworker/CNC/Mach3/Screens/M3Router.zip
Also, here's the Real Draw Pro files if anyone wants to modify the Screens (you'll need RealDraw Pro).
http://home.comcast.net/~cncwoodworker/CNC/Mach3/Screens/M3Router_RealDraw_Pro.zip
So, how do I change from inches to mm in this screenset?
« Reply #14 on: February 11, 2011, 10:48:11 AM »
Use the MDI, G21
« Reply #15 on: February 18, 2012, 05:59:15 PM »
The pngs are too large for my screen (1024x728). Can I just re-size them?
« Reply #16 on: February 19, 2012, 05:44:23 AM »
Just check Auto Screen Enlarge in General Config.
You can't resize them. The buttons won't be in the correct locations if you resize them.
Offline vav
  •  1 1
« Reply #17 on: March 16, 2012, 11:45:15 AM »
in the screen "Run machine" does not coordinates count "A", but on the screen"settings" is OK. You can make update file? thx. Vav
« Reply #18 on: March 17, 2012, 09:52:34 AM »
Try this one.
« Reply #19 on: September 27, 2022, 09:19:02 AM »
Somebody has the image files of this screenset in a more common format?
I would like to make some small adjustaments.
I was not able to find any converter able to convert the .rdw files (posted at the beginning of this thread) to a well-know vettorial format, for example svg.  :( :( :(
