Hello Guest it is October 24, 2026, 01:42:16 AM
Author Topic: 3D Probe Settings questions  (Read 11096 times)
« on: July 11, 2008, 10:23:31 PM »
Hi...
Just got my TP-100 Probe in today... seems to work great, but I have a few questions.
1.  Max Grid Increment setting...  what is the definition of this setting.  For example, if I set it to .01 if give me a point ever .01 of an inch.  But my question is, if it is set to say 1 inch for example, I assume it will put a point every inch regardless of a point being hit?  Or if hits a point between 0 and 1 inch it will record that point?   What is the recommended approach with this setting?  Does it depend on Object size?  I asking before experimenting so I don't destroy the probe in the process...
2. Probe Ball Diameter... mine is .076... what is this parameter doing?  I assume this compensates?
3. Probe Rate must rely on something else... probing seems slow any way you shake it... any suggestions or recommended settings?
4. Maximum Z height for stuck probe... what is this for, and more importantly, what is the definition of a stuck probe?
I have scanned, and the point cloud shows up in MachCloud, but I have had no luck in meshing the cloud to output to a .STL.   I can Mesh the "Prop" example, so I know I'm doing it right... but there must be some minimum point cloud settings I'm missing.
Thanks for any Advice.
Rich.
