Hello
Guest
it is
November 23, 2026, 10:15:56 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Modbus
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Modbus (Read 14942 times)
CJEls
69
Modbus
on:
July 11, 2008, 12:28:28 AM »
Hi All
I want to know If any body has written a plugin that works with the modbus pcb from cnc4pc. I want to setup a handwheel and cycle start, feedhold, x+, x-, Z+, Z-,plus selecting x or z axis for hand wheel with this board.
Thank you
CJ
Logged
poppabear
2,235
Briceville, TN, USA
Re: Modbus
Reply #1 on:
July 11, 2008, 01:20:41 AM »
I have a plug in that uses the mod bus, I am using the M13 board.........
It can jog all 6 axis at once, if you got the buttons........
I am adding some dialog stuff, and a few other bells and whistles.
BUT: having said the above, you can do all that you want above, with a "Brian"
scott
Logged
CJEls
69
Re: Modbus
Reply #2 on:
July 11, 2008, 02:00:07 AM »
Hi Poppabear
I Am a new be and willneed a lot of help.If I try and see if the board is working(m12)then I get A time out when reading the inputs.Do you have to have any links set on the control PCB.
Logged
poppabear
2,235
Briceville, TN, USA
Re: Modbus
Reply #3 on:
July 11, 2008, 04:38:07 AM »
get the docs for the M1, configure your serial port (the one on your computer).
then follow his instructions, for configing the Modbus, test the com that way.
down load his brain, for it, and follow those instructions.
there is too much crap with that stuff to try and tell you on a message. His docs go into far greater detail.
scott
Logged
Cruiser
106
Re: Modbus
Reply #4 on:
July 12, 2008, 10:00:50 AM »
Poppabear ! I don't have a "Brian" where oh where can i buy one ?
Sorry, I just had too !
Logged
CRUISER
Don
Print
Pages:
1
Go Up
« previous
next »
