Hello
Guest
it is
November 23, 2026, 10:39:40 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Ignore Tool Change
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Ignore Tool Change (Read 43233 times)
stevec
12
Ignore Tool Change
on:
December 09, 2005, 08:19:32 AM »
I am using Mach3 and am a new user. When I go to settings and unmark ignore tool change, all is fine until I shutdown. How do I make this stay off everytime I start up.
Logged
Brian Barker
3,860
Re: Ignore Tool Change
Reply #1 on:
December 09, 2005, 08:26:00 AM »
please change the setting and exit Mach3. When you exit Mach 3 it should save the setting. The Exit needs to be done by closing the software not by powering down the computer.
Hope that helps
Brian
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
stevec
12
Reply #2 on:
December 09, 2005, 09:52:05 AM »
Been there, done that.
Change settings and go to file exit. Open back up and no save for settings. I am using Version R1.83.030
Logged
Brian Barker
3,860
Reply #3 on:
December 09, 2005, 11:53:33 AM »
Could you send me your XML file and I will have a look at it. I have tested it here and it is working as it should... I am tinking you may have a bad XML.
Thank you
Brian
Logged
www.machsupport.com
stevec
12
Reply #4 on:
December 09, 2005, 12:01:47 PM »
Brian,
Please tell me where the XML file is and where to send it
STeve
Logged
Brian Barker
3,860
Reply #5 on:
December 09, 2005, 12:07:48 PM »
The XML is in the Mach3 directory and is going to be named Mach3Mill .xml if you are using mill. If you are using a lathe it will the the turn XML
You can send it to me a brianb@newfangledsolutions.com
Brian
Logged
www.machsupport.com
stevec
12
Reply #6 on:
December 09, 2005, 12:11:49 PM »
File is on the way!
Logged
stevec
12
Reply #7 on:
December 09, 2005, 12:49:27 PM »
Brian,
Got the new code and replaced it. Started machine and yes ignore tool change is now off, BUT, If I now set it to on and exit the program then reopen it, the button remains off
Logged
Brian Barker
3,860
Reply #8 on:
December 09, 2005, 12:54:09 PM »
I think you my have to reinstall Mach3. I tested your XML here and it looked great! I have seen this problem
Thank you and sorry the XML didn't do it
Brian
Logged
www.machsupport.com
stevec
12
Reply #9 on:
December 09, 2005, 12:57:19 PM »
Thanks for all your help.
How can I save all my machine settings and tool setups before I reinstall mach3. Or cant I
Steve
Logged
Print
Pages:
1
2
Go Up
« previous
next »
