Hello Guest it is October 21, 2026, 02:26:33 AM
Author Topic: SHERLINE ROTARY TABLE MOTOR MOUNTING  (Read 12149 times)
« on: July 06, 2008, 03:39:28 PM »
Nothing fancy. Just showing how a stepper motor was mounted to a Sherline rotary table.
The square adapter under the table allows for easy insertion into a vise and provides for centering of the table to the block.
The adapter can be remove and holes in the adapter ( can't see them ) allow for mounting to a sine and right angle plate.
The stepper motor mount was made from a scrapped assembly "save good junk". Will change out stepper with one having dual shafts so it can be used manually.
Offline Glenn
  •  129 129
Re: SHERLINE ROTARY TABLE MOTOR MOUNTING
« Reply #1 on: October 21, 2008, 05:36:08 PM »
Rich,
   Great work! Does this rotary go on a sherline mill, or retro fit
to your router table for 4th axis usage?
  All junk is GOOD ;D  Glenn
Don't assume anything.....it'll make a Manager out of U and Me!
« Reply #2 on: October 21, 2008, 06:00:28 PM »
Good Job Rich. I have to build a rotary table for the Hurco soon.
