General CNC Chat => Show"N"Tell ( What you have made with your CNC machine.) => Topic started by: RICH on July 06, 2008, 04:39:28 PM
Nothing fancy. Just showing how a stepper motor was mounted to a Sherline rotary table.
The square adapter under the table allows for easy insertion into a vise and provides for centering of the table to the block.
The adapter can be remove and holes in the adapter ( can't see them ) allow for mounting to a sine and right angle plate.
The stepper motor mount was made from a scrapped assembly "save good junk". Will change out stepper with one having dual shafts so it can be used manually.
Rich,
Great work! Does this rotary go on a sherline mill, or retro fit
to your router table for 4th axis usage?
All junk is GOOD ;D Glenn
Good Job Rich. I have to build a rotary table for the Hurco soon.
