Hello Guest it is October 21, 2026, 07:50:40 AM
Author Topic: im service parrellel sys- 4 mach3 setup  (Read 15693 times)
« on: July 06, 2008, 12:58:51 PM »
i was hoping some one has perchased one of these im service sys-4 systems and could help me
understand the setup .  cant get much help from imservice .
does any one have sreenshots of the setup.
i was also wondering how the encoders work when i only give it step and dir
thanks for the help
Re: im service parrellel sys- 4 mach3 setup
« Reply #1 on: July 06, 2008, 01:52:52 PM »
Just had a look at their site and cant find any real info there I am afraid.
Encoders are used between motor and drives so that the drive knows where the motor is and the speed of it, your encoders should plug into the drives.
Do you know what components you have and do you have any pics?
« Reply #2 on: July 06, 2008, 02:16:09 PM »
loot,
What exact kit / system did you buy? Did it include one of their controller boxes which have drives and a board?
Most of the cables you recieved should just plug into the controller and then it's a matter of configuring MACH.
Maybe MACH is already configured based on a Sherline package and associated motors.
Think folks in here would be more than happy to help you out. I would have thought that Fred would at least
waver the $60 a year IMSERVICE forum fee until you got things hooked up.
« Reply #3 on: July 06, 2008, 05:25:49 PM »
i bought the sys-4 3axis box and i setup my step dir pin on mach but i  get just a small ammount of movement out of my motors
I know there is power to them because the lock up when i turn the power on.
it is the 3 axis parrellel port system.
it has a cnc4pc c10 breakout board and deskcnc servo driver board.
dont know if im missing something on mach setup
i have a stepper motor cnc system that works fine but cant get this one to work.
my motors turn real slow and some times not at all
i have a 1/2-13 thread  dont know what the correct settings are for the servo motors
for steps /in. -velocity- accelleratio
the sherline systems use the serial port and deskcnc software  this one is parellel port.
thanks for the help
« Last Edit: July 06, 2008, 05:58:16 PM by loot »
« Reply #4 on: July 06, 2008, 06:28:09 PM »
What are  the encoder lines? possibly 500ppr?
