Hello Guest it is September 06, 2026, 12:48:55 AM
Author Topic: z-axis problem  (Read 40599 times)
Offline euro
  •  14 14
z-axis problem
« on: June 30, 2008, 07:02:57 PM »
hi folks,im new here.im having a problem with mach3. when i zero my x axis and then i jog it up by say .378 it moves 3.78 on the dro so when i run code i dont get the right depths any ideas thanks
Re: z-axis problem
« Reply #1 on: June 30, 2008, 07:06:00 PM »
Sounds like your steps per aren't set right in motor tuning or maybe you have changed the drive from 10 mirosteps to no micro steps. Is this a new set up?
Offline euro
  •  14 14
Re: z-axis problem
« Reply #2 on: June 30, 2008, 07:12:35 PM »
thanks brett for your quick respond . no this isnt a new setup it was workin fine on friday but today its got the monday blues , this machine is a plasma/router table when i run it in plasma everythin is fine but not in routerin
Offline euro
  •  14 14
Re: z-axis problem
« Reply #3 on: June 30, 2008, 07:14:28 PM »
where do you find the microsteps in mach
Re: z-axis problem
« Reply #4 on: June 30, 2008, 07:16:05 PM »
OK, you are running 2 different profiles?  Have a look at motor tuning, steps per for each profile if you are and compare the z axis steps per.
Re: z-axis problem
« Reply #5 on: June 30, 2008, 07:16:52 PM »
Micro steps arent set in Mach and if all the hardware is the same between the set ups, it will be a config. issue.
brett
Re: z-axis problem
« Reply #6 on: June 30, 2008, 07:20:29 PM »
Hi..maybe a 10:1 Scaling inadvertantly set ?
Offline euro
  •  14 14
Re: z-axis problem
« Reply #7 on: June 30, 2008, 07:24:02 PM »
yes im runnin two profiles and i did check moter tunning and there the same in both profiles. i dont have config issue on my screen
Offline euro
  •  14 14
Re: z-axis problem
« Reply #8 on: June 30, 2008, 07:26:00 PM »
sorry brett i see what you ment its a config issue
Offline euro
  •  14 14
Re: z-axis problem
« Reply #9 on: June 30, 2008, 07:29:04 PM »
were in mach would a 10;1 issue happen
