Mach Discussion => General Mach Discussion => Topic started by: euro on June 30, 2008, 08:02:57 PM
hi folks,im new here.im having a problem with mach3. when i zero my x axis and then i jog it up by say .378 it moves 3.78 on the dro so when i run code i dont get the right depths any ideas thanks
Sounds like your steps per aren't set right in motor tuning or maybe you have changed the drive from 10 mirosteps to no micro steps. Is this a new set up?
thanks brett for your quick respond . no this isnt a new setup it was workin fine on friday but today its got the monday blues , this machine is a plasma/router table when i run it in plasma everythin is fine but not in routerin
where do you find the microsteps in mach
OK, you are running 2 different profiles? Have a look at motor tuning, steps per for each profile if you are and compare the z axis steps per.
Micro steps arent set in Mach and if all the hardware is the same between the set ups, it will be a config. issue.
brett
Hi..maybe a 10:1 Scaling inadvertantly set ?
yes im runnin two profiles and i did check moter tunning and there the same in both profiles. i dont have config issue on my screen
sorry brett i see what you ment its a config issue
were in mach would a 10;1 issue happen
Yup, Overloaded is right I bet. Do you have any scaleing values in your scaleing dros? Small dros just beside the axis dros on the program run screen. Should be 1:1.
i bet i do never notice ill have to run to the shop and see the people where i bought made there own screen so it is diferent than the default screens thanks for your help ill get back and post my findings
no i dont have scaling dros is there somewhere in mach where i can scale from
euro,
Can you post your xml files and your screen sets? I will look at those and try to find the problem.
You might enter a G50 in the MDI to be sure all scaling is cancelled and reset to 1:1, then try the move again.
RC
thanks a lot for your help i got a hold of tec support and he thinks i must of typed in 2000 instead of 20000 steps under moter tunning ill double chek that in the morning agian thanks
Brett had that nailed for you in the beginning......I didn't realize you had changed stuff.
RC
the problem started when i ran a file i got from the vectric forum could it had been what was in the g codes that changed the settins i know i didnt
brett also mention microsteps that i might have changed it where do you find the settins for the microsteps so i can also check that thanks
Follow these steps..if your steps per is 2000, make it 20000 then be sure to save, then try the Z move again.
Euro, If it is the code that changed it, it would probably be a G20 or a G21 but the ratio isn't 10-1. It will put your machine in Imperial or metric units. Go to MDI and typr in G 20 G 50 and hit enter. Now type G1 X1 F10. Does it travel 1 inch?
Micro steps are not set in Mach, they would be set on the drives. If you haven't changed anything mechanically, I doubt this is the case. Some drives change this option with dip switches, others with jumpers I think (possibly one fell off due to vibration?) and others aren't adjustable.
I dont know how the G code could change it to where a G50 would not clear it if it was scaled. I'm almost certain that it would not change the configuration settings in Mach.
Did you CLOSE the G code in Mach before you did the jogging ?
There could be an active G51 in the loaded code...if there is a program loaded.
Anyway, G50 Z.378 in MDI would clear it.....I think,
RC
Euro, I see in your first post now ...you said you jogged the X axis UP. I mistook this for the Z axis. Sorry
Good luck guys,
I'll check back tomorrow.
Brett, I just thought we could verify with the steps per setting before going into the hardware panel.
AMF,
RC
you were right brett the moter tunning was wrong thanks,everything is good now,back to relax,this is a great forum
No problem, glad you are sorted. :)
