Hello Guest it is October 30, 2026, 04:22:52 PM
Author Topic: External Feedrate adjustment  (Read 18679 times)
« on: May 25, 2006, 03:39:25 PM »
Is there any way to put a remote (external) nob or adjustment mechanism to change the feedrate ?
example would be something that will connect to break out board for Parallel ?
Curtis
Re: External Feedrate adjustment
« Reply #1 on: May 25, 2006, 03:55:22 PM »
The only way that I have done it is with a PLC and an analog pot :( But if you hook up two buttons (one for feed up and one for feed down) I can get them to work in Mach3 :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: May 25, 2006, 05:06:50 PM »
I am sure John P uses an external pot or rotating switch to adjust feedrate, might be worth a look in the wikis to see if hes detailed it there.
Edit
 had a look and John P uses it in conjuction with the ModIO
« Last Edit: May 25, 2006, 05:33:21 PM by Hood »
vytass
« Reply #3 on: June 27, 2006, 07:04:21 AM »
I think we can use joystick port analog inputs. We use it in our aplication (not Mach). We use two axis 8 button USB joystick. X axis for   spindle speed, Y axis for feedrate and buttons for jogging (X,Y, Z ,Cycle start, Cycle stop). Works well. How we can use it vith Mach3?
« Reply #4 on: June 27, 2006, 06:13:47 PM »
This can be done but a plugin would need to be written...
www.machsupport.com
vytass
« Reply #5 on: June 28, 2006, 04:12:17 AM »
Let it be suggestion to include it in new mach version. You can  improve this  products with it usefull function.
