Hello Guest it is October 21, 2026, 03:07:49 AM
Author Topic: Idea compensation planarità  (Read 13560 times)
« on: June 27, 2008, 06:47:00 AM »
Hi to all. be a good idea, set zero the utensil in default points, to make to calculate to Mach3 a compensation of the planarità of the surface of support of the piece to work? excuse my English. Hi to everybody. Giordano
Re: Idea compensation planarità
« Reply #1 on: June 27, 2008, 09:53:00 AM »
Sorry Giordano, dont understand what you are asking :(
« Reply #2 on: June 27, 2008, 01:51:31 PM »
Sorry .... sometimes the work plan is not perfectly linear. From x0 to xmax and y0 to ymax could be a small difference in height. It would be a good idea to make Mach3 setting these values be able to perform processing offsetting these differences. Hello Giordano.
« Reply #3 on: June 27, 2008, 06:45:23 PM »
Hello Giordano,
Do you mean to have Mach compensate for a twisted or warped table and have the Z axis Zero always the same distance from the table ?
  If that is what you mean, I'm not sure that it can. You would probably need to true up your machine.
RC
