Mach Discussion => General Mach Discussion => Topic started by: giordano on June 27, 2008, 07:47:00 AM
Hi to all. be a good idea, set zero the utensil in default points, to make to calculate to Mach3 a compensation of the planarità of the surface of support of the piece to work? excuse my English. Hi to everybody. Giordano
Sorry Giordano, dont understand what you are asking :(
Sorry .... sometimes the work plan is not perfectly linear. From x0 to xmax and y0 to ymax could be a small difference in height. It would be a good idea to make Mach3 setting these values be able to perform processing offsetting these differences. Hello Giordano.
Hello Giordano,
Do you mean to have Mach compensate for a twisted or warped table and have the Z axis Zero always the same distance from the table ?
If that is what you mean, I'm not sure that it can. You would probably need to true up your machine.
RC
