Hello Guest it is November 23, 2026, 11:07:48 AM
Author Topic: Trouble activating relay thru breakout board.  (Read 22034 times)
Offline Bobo
  •  41 41
    • Haus Metalworks
« on: May 24, 2006, 08:20:12 AM »
I'm still having problems trying to activate a relay to turn on/off my plasma torch. I have the relay hooked up to the out 1 terminals on the breakout board from Campbell designs and I was trying to activate it with the spindle toggle button on the Diagnostics page with no success. When I hit the flood and mist buttons the respective lights glow on the Diagnostics page but still did not activate the outputs on the breakout board for output 1, 2 or 3.
Thanks in advance for any insight.
Re: Trouble activating relay thru breakout board.
« Reply #1 on: May 24, 2006, 09:17:01 AM »
Did you set the ports and pins?
www.newfangledsolutions.com
www.machsupport.com
Offline Bobo
  •  41 41
    • Haus Metalworks
« Reply #2 on: May 24, 2006, 03:23:01 PM »
I set the spindle output device to output 1 and uncheck the not used box, I left spindle axis enabled and PWM control unchecked for the port setup and have Output #1 set to port 1 and pin 1.
« Reply #3 on: May 24, 2006, 06:24:46 PM »
Could you please post your XML so I can have a look at it.
Thank you
Brian
www.machsupport.com
Offline Bobo
  •  41 41
    • Haus Metalworks
« Reply #4 on: May 25, 2006, 07:07:56 AM »
Here is my Profile.
« Reply #5 on: May 25, 2006, 10:22:36 AM »
Well it looks like it is turning on... Is there a setting on the board that is not right? also swap the pins 1 and 16 in the software and see if you can get it to work...
www.machsupport.com
Offline Bobo
  •  41 41
    • Haus Metalworks
« Reply #6 on: May 26, 2006, 10:16:20 PM »
OK.. I started over again with Mach 3 and everything is working fine now. Thanks for your help.
« Reply #7 on: May 26, 2006, 11:25:52 PM »
Nice!  8)
www.machsupport.com
