Hello Guest it is November 22, 2026, 02:10:14 PM
Author Topic: Combining various vbscript and gcode into a file versus a button  (Read 16536 times)
vss
I have a fairly long and busy set of vbscript programming behind two of my buttons.  I was wondering if there is a way to call or reference a file that contains that code versus pasting it all behind the button.  Anyone know how I would do this?  Also, I would like to hide the vbscript from someone using the screen designer to review my screen pages.  Is there a way to do this as well?
Thanks...
Re: Combining various vbscript and gcode into a file versus a button
« Reply #1 on: May 23, 2006, 02:22:36 PM »
You could put your VB code into an Mcode and call the Mcode from the button... IS that what you are looking for?
www.newfangledsolutions.com
www.machsupport.com
vss
« Reply #2 on: May 23, 2006, 03:44:34 PM »
The M code sounds good.  Is there then a way to put all the code for the M command into one file that can be included with my installation?  Essentially one central place where all of this can be placed, and essentially hidden from the typical user.  I want to make it easy to use, and hard to screw up.
« Reply #3 on: May 23, 2006, 09:32:20 PM »
You have to put the macro in the Mach3/macros/mach3Mill folder.. you can hide the Macro with windows
hope that helps
Brian
www.machsupport.com
