Hello Guest it is October 21, 2026, 03:47:38 AM
Author Topic: Galil+mach3  (Read 12693 times)
Galil+mach3
« on: June 25, 2008, 12:43:12 AM »
hi all
      i having galil DMC-2123 controller. i am running galil controller through MACH3.
      1:can i use the DMC-2123 controller input / output (other than limit and home) using MACH3
      2:how can i interface my software with MACH3
          i want to start MACH3 motion through my software.
     my configuration is :  Controller: DMC-2123
                                   drive (daughter card) :SDM-20640
Re: Galil+mach3
« Reply #1 on: June 25, 2008, 09:00:02 AM »
? do you mean you have your own Software interface and you want to call mach3 under it, if so, look at the downloads for the Remote Mach SDK.
Re: Galil+mach3
« Reply #2 on: June 26, 2008, 11:20:35 AM »
ahhh,
  got a hold of Hillbilly, you take the Inputs and Outputs on the galill card, and set that I or O to its equivelent pin number.
The Galil loads as Port 1 in Ports and Pins,
So Input Pin on the Galil would equat to Port1, Pin1 on inputs, So, INPUT1 = 1, 1
INPUT2 = 1,2  etc.
Scott
